Agilent/HP/83623A
企业: | |
日期: | 2010-03-05 |
领域: | 未设置 |
点击数: | 412 |
Agilent/HP/83623A
详细资料:
描述
The Agilent 83623A synthesized sweeper is the standard of excellence for applications requiring the high performance and accuracy of a synthesized source and the speed and versatility of a sweep oscillator. Synthesized broadband frequency coverage and precise 1 Hz frequency resolution (Opt 008) are generated by indirect synthesis, enabling the Agilent 83623A to achieve low single-sideband phase noise performance. It delivers harmonic performance of 25 dB below the carrier from 2.0 to 20 GHz.
Scan modulation to simulate antenna scan patterns
Accurate fixed and swept frequency offset for two-tone measurement
User flatness correction for leveling at remote points in the test system
General purpose source for use in component test, receiver test and for frequency conversion
Sweep Modes: Step, List, Ramp
Maximum Power: +17 dBm
Power Sweep Range: -20 dBm to maximum power
Phase Noise (20 GHz at 10 KHz): -76 dBc
Max FM Deviation (locked): +/- 8 MHz
仪器保证:
我们的大多数设备在装运之前均经过严格的质量检测与校验。也可申请国家计量证书
