技术 |
IEEE 802.3 10Base-T IEEE 802.3u 100Base-TX IEEE 802.1p Class of Service IEEE 802.1Q Quality of Service ITU-T G.993.2 VDSL2 | |
技术 |
存储转发技术,具有64~1792字节数据包转发能力 | |
2K with 300 Sec agent time | |
4 Packet forwarding queues with 1 (Lowest):4 (Low):8 (High):15 (Highest) WRR (weighted round robin) forwarding schematics | |
VLAN tag priority, IPv4 packet precedence and IPv6 ToS. | |
快速以太网: 每秒200数据包 @ 100Mbps; 每秒20数据包@ 10Mbps | |
界面 |
1 x 10/100Mbps 快速以太网接口,具有MDI/MDI-X功能,速率自适应 1 x Line ISDN或电话端口 1 x VDSL2 端口 | |
10/100 Base-TX: RJ-45具有MDI/MDI-X功能,速率自适应 ISDN/POTS: RJ-11 VDSL 2: RJ-11 | |
RJ-45 快速以太网端口: 4类或5类线, 2对屏蔽双绞线, 最多100 米 VDSL2: 1对屏蔽双绞线, 最多3000英尺 Line: ISDN或电话 | |
DIP-1(模式选择): On (Master)/Off (Slave) DIP-2(Impulse protection): On (Interleave)/ Off (Fast); Interleave mode with less than 250ms forwarding latency, Fast mode is less than 2 ms forwarding latency. DIP-3(Rate Control): On (Non-Symmetric)/Off (Symmetric) DIP-4(SNR Control): On (6dB) /Off (9dB) | |
系统上电: 打开电源 (绿灯亮) 快速以太网端口: 速率 (100Mbps: 黄灯亮), 连接/ 激活 (绿灯) (亮: 10 or 100Mbps 已经连接, 闪: 数据包传送中) Master (绿灯亮): 设备在Master模式下操作. VDSL 连接/协商 (绿灯): 亮/ 已连接, 闪/协商中 | |
电源需求 |
DC jack: 12~48V, 3-Pin, ? 2mm Center Pin 接线端子: DC 12~48V, 3线接线端子,带地线. 输入电源带反接保护 | |
机械规格 |
29mm(H) x 88mm (W) x114 mm (D) | |
工作环境 |
通过认证 |
FCC Class B; CE/EN55022:2003,class B; CE/EN61000-3-2:2001 Harmonic TestCE/EN61000-3-3:1995 Flicker test | |
FCC class A, CE/EN55022 class A | |
IEC61000-4-2 , IEC61000-4-3, IEC61000-4-4, IEC61000-4-5, IEC61000-4-6, IEC61000-4-8 | |
5366,967 小时 ,MIL-HDBK-217F | |
