昭营2.5寸嵌入式电脑模块 VSX-6115
企业:深圳市昭营科技有限公司 日期:2008-08-12
领域:传感器 点击数:1008
128MB/4S/USB/VGA/LCD/LAN/GPIO
Specifications
SoC:
DM&P SoC CPU Vortex86SX- 300MHz
Real Time Clock with Lithium Battery Backup
Cache:
L1:16K I-Cache, 16K D-Cache
Bus:
16-bit x-ISA interface
BIOS: AMI BIOS
System Memory: 32MB/64MB/128MB DDR2 on board
Watchdog Timer:
Software programmable from 30.5 to 512 seconds x 2
sets (Watchdog 1 fully compatible with M6117D)
LAN:
Intergraded 10/100M Ethernet
Flash Disk Support:
Onboard 2MB SPI Flash Disk (Optional)
MSTI EmbedDisk Module (16MB and above)
I/O Interface:
Enhanced IDE port (UltraDMA-100/66/33) x1
RS-232 port x3
RS-232/485 port x1
USB port (Ver2.0) x2
Parallel port x1
32-bit GPIO port x1
10/100Mbps Ethernet port x1
Connectors:
2.0mm 44-pin box header for IDE x1
2.0mm 26-pin box header for Printer x1
2.0mm 20-pin box header for 16-bit GPIO x2
2.0mm 10-pin box header for RS-232 x4
2.0mm 10-pin box header for USB x1
2.5mm 5-pin box header for Keyboard x1
2.5mm 5-pin box header for Mouse x1
2.54mm 3-pin header for RS-485 x1
1.25mm 6-pin header for JTAG x1
External RJ-45 connector for Ethernet x1
Power Requirement:
Single Voltage +5V @ 250mA
Weight:76g
Board Size: 100 X 66mm (3.94 x 2.6 inches)
Operating Temperature:-40℃ ~ +85℃
