F&C嘉准 FSC1202-N圆形近接开关
企业:东莞市嘉准电子科技有限公司 日期:2008-07-17
领域:传感器 点击数:721
产品简介:
检出距离:2mm
建议距离:1.5mm
标准检测物:12*12*1(iron)
详细介绍:
Scanning distance/检出距离 2mm
Recommened distance/建议距离 105mm
Standard sensing object/标准检测物 12*12*1铁
Response frequwncy/反应频率 DC:600Hz/AC:20HZ
Hysteresis/磁滞 ≤1O% ofsensing distance
Operating Voltage/工作电压 DC:12~24VDC±10%/AC:90~260V
Current consumption/消耗电流 DC:≤8mA No—Load/AC:2mA Max
Output Current/负载电流 DC:30V 200mA Max/AC:5-200mA Max
Leakage current/漏电流 DC:≤1.1mA no-Load/AC:2.OmA no-Load
Residual voltage/残余电压
DC:≤1.5VDC/AC:≤4VAC
Operating temperature/工作温度范围 -20°C~+70°C
Housing/外观方式 ABS/CUPRUM
Wiring method/也线方式 4φ*2M/3 Cores
Degree of portection/防水等级 IP66
定购网址:
产品介绍网址: www.fctaiwan.com
