F&C嘉准 FSND04-N方型近接开关
企业:东莞市嘉准电子科技有限公司 日期:2008-07-02
领域:传感器 点击数:810
产品简介:
检出距离:4mm
建议距离:3.2mm
标准检测物:10*10*1(iron)
详细介绍:
Scanning distance/检出距离 4mm
Recommened distance/建议距离 3.2mm
Standard sensing object/标准检测物 10*10*1(iron)
Response frequwncy/反应频率 DC:600Hz/AC:20HZ
Hysteresis/磁滞 ≤1O% ofsensing distance
Operating Voltage/工作电压 DC:12~24VDC±10%/AC:90~260V
Current consumption/消耗电流 DC:≤8mA No—Load/AC:2mA Max
Output Current/负载电流 DC:30V 200mA Max/AC:5-200mA Max
Leakage current/漏电流 DC:≤1.1mA no-Load/AC:2.OmA no-Load
Residual voltage/残余电压
DC:≤1.5VDC/AC:≤4VAC
Operating temperature/工作温度范围 -20°C~+70°C
Housing/外观方式 ABS
Wiring method/也线方式 4φ*2M/3 Cores
Degree of portection/防水等级 IP66
产品介绍网址:
