ABB(www.abb.com)是电力和自动化技术领域的全球领导厂商,致力于为工业和电力行业客户提供解决方案,以帮助客户提高业绩,同时降低对环境的不良影响。ABB集团的业务遍布全球100多个国家,拥有12万名员工,2008年销售额约为350亿美元。 ABB集团位列全球500强企业。集团总部位于瑞士苏黎世,并在苏黎世、斯德哥尔摩和纽约证券交易所上市交易。ABB由两个历史100多年的国际性企业-瑞典的阿西亚公司(ASEA),和瑞士的布朗 勃法瑞公司(BBC Brown Boveri) 在1988年合并而来的。
使用机器人IRB6640
机器人和扫描振镜结合的激光飞行焊接能在大工作范围内带来高柔性和高效能
ABB robot and laser scan head cooperated for flexibility and productivity in large working area
无需额外的主机即可协调处理扫描振镜和机器人运动实现飞行焊接
No need of a master PC to coordination of scan head and robot motion for on-the fly welding
简单易用且内置有机器人运动和激光设备接口的专用飞行焊接指令
Easy of use specific welding instruction enhanced robot motion and laser interface
在线调试工具RLW Analyst 和 离线编程工具 RobotStudio Add-in可进行快速、强健的编程调试
On-line tool RLW Analyst and off-line tool RobotStudio Add-in for fast and robust commissioning
新一代大型机器人IRB 6700的点焊应用
Spot welding with new generation large robot IRB 6700
可靠且兼具成本效益的大型机器人IRB 6700
Reliable and cost effective large robot IRB 6700
SafeMove™安全选件开启人机协作新时代
SafeMove ™enable the truly human-machine collaboration
配置完善的即用型机器人功能包为高品质高性能点焊提供助力
Fully configured, ready-to use robot packages for high quality and high performance spot welding
采用Lean ID增加Dress pack使用寿命
Available with Lean ID to increase dress pack lifetimes
性能卓越的模块化点焊枪ABB FlexGun
High performance and modular spot welding gun ABB FlexGun
快速、功能丰富的ABB电极修磨器
High process speed and wide range ABB electrode tip dresser
IRB 1520ID弧焊
IRB 1520ID arc welding
弧焊专用中空臂机器人IRB 1520ID
Dedicated arc welding robot IRB 1520ID
采用第二代TrueMove™ & QuickMove™ 技术实现了路径精度最优化和两次焊接间的加速度最大化
Outstanding path accuracy and maximum acceleration between welds
软管束与焊接电缆分别同上臂和底座紧密集成使得机器人在狭小区域的运动更加灵活
Available with ID for easy accessing in narrow spaces for more flexible movements.
高可靠性的碰撞检测功能保护设备及工件
High reliability collision detection solution protect equipment and work pieces
IRB 1200迷宫大作战
Compete with IRB 1200 in Maze
采用最具成本效益的小型机器人IRB 1200
A compact, flexible, fast and functional small industrial robot
兼顾紧凑性和有效工作范围优势
Long reach while providing compactness
速度提高10%,优异的精准度与敏捷性
10% shorter cycle times with superior accuracy and agility
配备新一代的高性能的紧凑型控制柜
Equipped with the new generation compact controller
