德恩科电机是世界一流的运动控制领域的领先制造商,早在1991年便成为了世界首批通过ISO 9001认证的小型电机制造厂商之一。它提供的优质的传动控制解决方案,满足了客户对成本和可靠性日益增长的需求。
Dunkermotoren opens R&D Center in Taicang德恩科电机在太仓启动科研中心
厂商:德恩科电机(太仓)有限公司
  点击数:2504  发布时间:13-09-23 13:02
近期,德恩科电机正式启动了位于其在江苏省太仓市的工厂内的研发中心。该研发中心服务于整个阿美德格精密控制产品部,提供在产品开发过程中的专业技术,实现直线及旋转电机的本地化及高品质。
  Recently, Dunkermotoren officially inaugurated a brand-new R&D center at its premises in Taicang, Jiangsu. The R&D center in Taicang will provide technical expertise in regards to product development, localization and qualification of linear as well as rotary drives (I think ‘drives’ should be ‘motors’, the same below) for the entire AMETEK PMC division.
  The R&D center covers about 200 square meters and is equipped with dynamometers rated from 50mNM to 200NM for drive performance testing of miniature as well as large gear motors. Noise spectrum analyzer, magnet property tester, and an environmental testing room enable our highly skilled engineers to put all Dunkermotoren and PMC drives (motors) through its paces.
  该研发中心占地约200平方米,配备了范围为50mNM到200NM的测功机,用于微型电机及大力矩齿轮电机性能测试。另外,还拥有噪音频谱分析仪、磁性测试器以及一个环境检测室。我们优秀的工程师如虎添翼, 将确保德恩科及PMC的电机产品领先世界。
  Customer response times for special drive (motors) solutions as well as time-to-market for new drive products will be significantly reduced thanks to the new R&D facility.
  有了该研发中心,需要特殊产品的客户会得到及时的服务,新产品的上市时间也将会大大缩短。
  Corporate Profile: Dunkermotoren belongs to AMETEK, a leading global manufacturer of electronic instruments and electro-mechanical devices with annualized sales of $3.4 billion. AMETEK’s Corporate Growth Plan is based on Four Key Strategies: Operational Excellence, Strategic Acquisitions & Alliances, Global & Market Expansion and New Products. The common stock of AMETEK is a component of the S&P MidCap 400 and the Russell 1000 Indices.
  公司简介:德恩科电机隶属于阿美德格集团,该集团是世界领先的电子仪器及电子机械产品制造商,年销售额达34亿美元。阿美德格集团的发展得力于其四大方针:卓越运营、战略并购及联盟、全球市场扩张和开发新产品。阿美德格集团的普通股票为S&P MidCap 400 和Russell 1000指数的组成部分。
