详细介绍: Scanning distance/检出距离 10mm Recommened distance/建议距离 39.0mm Standard sensing object/标准检测物 30*30*1铁 Response frequwncy/反应频率 100Hz/AC:20HZ Hysteresis/磁滞 ≤1O% ofsensing distance Operating Voltage/工作电压 DC:12~24VDC±10%/AC:90~260V Current consumption/消耗电流 DC:≤8mA No—Load/AC:2mA Max Output Current/负载电流 DC:30V 200mA Max/AC:5-200mA Max Leakage current/漏电流 DC:≤1.1mA no-Load/AC:2.OmA no-Load Residual voltage/残余电压 DC:≤1.5VDC/AC:≤4VAC Operating temperature/工作温度范围 -20°C~+70°C Housing/外观方式 ABS Wiring method/也线方式 4φ*2M/3 Cores Degree of portection/防水等级 IP66 | |||
定购网址: |
产品介绍网址: www.fctaiwan.com
