艾默生(美国纽约证券交易所代码: EMR)是一家全球性的技术与工程公司,为工业、商业及住宅市场客户提供创新性解决方案。自动化解决方案业务帮助过程、混合和离散行业制造商优化其能效和运营成本,促进生产,确保人员安全和保护环境。商住解决方案帮助确保人类舒适度和健康,保障食品质量和安全,提升能效,打造可持续发展的基础设施。如欲了解更多信息,欢迎访问:www.emerson.cn。
中国?上海(2016年10月17日)-艾默生自动化解决方案推出AMS Trex设备通讯器,这是一款便携式通讯器,可以提供直观的用户体验并内置了杰出的现代化显示屏,适用于严酷的工业环境。借助人性化设计理念,Trex通讯器配备的基于任务的图形化用户界面可以使设备诊断及回路诊断变得简单易懂,并且现场活动也更加易于完成。
“With the Trex communicator, technicians can work more effectively in the field – with fewer tools to manage – anywhere in the plant they need to go,” said Duncan Schleiss, vice president, reliability solutions marketing, Emerson Automation Solutions.
艾默生可靠性解决方案市场副总裁Duncan Schleiss表示:“Trex通讯器可以帮助技术人员在现场更高效地工作,管理更少的工具,在工厂中任意所需位置。”
Protected against moisture and extreme temperatures, the Trex communicator boasts a rugged design that can withstand the bumps and drops that come from normal use in the plant. The large, full-color touchscreen display adjusts to lighting conditions and aids troubleshooting in areas where too much or too little light makes other devices difficult to read.
Trex通讯器拥有坚固的设计,它即可以耐受潮湿和极端温度,又可以耐受在工厂正常使用过程中的碰撞和摔落。大尺寸、全彩触摸显示屏可以根据光照条件进行调整,并有助于在光线太强或太弱而使其他设备无法读取数据的区域进行故障排查。
With intrinsic safety certifications, the Trex communicator is certified to go anywhere a technician can go, with no need to shut a process down or get a hot work permit. Long-life batteries ensure that the communicator keeps working even through long days.
Trex通讯器通过了本安认证,适用于技术人员所需前往的任何位置,而无需过程停车或获得热作业许可证。长寿命电池确保了该通讯器可以持续工作长班次。
Using the Trex communicator’s built-in Foundation Fieldbus and HART device diagnostic software, technicians can isolate and repair problems while the devices continue to run. Simple issues can be addressed on the spot, avoiding unnecessary interruption to production. Segment and loop diagnostic tools allow users to validate loop and fieldbus segment characteristics for easy troubleshooting. With the ValveLink Mobile app, technicians can analyze valve diagnostics results easily on the communicator’s larger screen.
凭借Trex通讯器内置的基金会现场总线及HART设备诊断软件,技术人员可以在设备持续运行的状况下隔离设备并对其维修,简单的问题将立即得到处理,从而避免造成不必要的生产中断。网段和回路诊断工具允许用户验证回路及现场总线分段特性,以便于排查故障。通过ValveLink移动版app,技术人员可以轻松地分析通讯器大尺寸屏幕上所显示的阀门诊断结果。
For more information on the Trex Communicator go to www.emerson.com/trex.
如需了解更多Trex通讯器的相关信息,请登录www.emerson.com/trex。
